Hi everyone! I've got the question about generating terminal strip drawings.
When we generate terminal strip drawing we have wiring diagram with the next characteristics. From the terminal strip's side we can see (can set visible) wire marks and cable core marks both. From the destination's side we see (can set visible) only cable core marks. But I want to see wire marks from the both sides. Is there any possibility to generate terminal strip drawings as i want?
When workers will wire cables between junction boxes first that they will do it's installing wire marks on a cable cores and then cable cores marks means nothing for them. Also not all cables have cable core marks. That's why I need wire marks from the both sides in terminal strip drawings.
Further I'll show you everything more pictorial...
From the terminal strip's side we can see wire marks and cable core marks both. From the destination's side we see only cable core marks.
In the window of terminal strip drawing configuration we can't set wire marks visible from the destination's side.
But I want to have this kind of schematics.
