In the picture above you will see a PCB board I am wanting to animate it sliding into the enclosure. Thus simulating someone installing the board. Line C and Vertex A are mated to each other in a path mate. Line D and Vertex B are mated together in a path mate as well. When going into a motion analysis it says that the mate cannot be free. So I set it to a percentage of the path. But it will not let me do it to the other path at the same time. So when I try to animate it with a motor in motion analysis I can get it to work correctly. Does anyone have experience making a motion analysis with two path mates? Or does anyone have a better way to accomplish this. Thanks in advance.
Simple Fix. Apparently I just needed to step away from the machine for a minute. I kept the curved path for my path mate. But I changed the straight line path mate to a coincident mate and everything worked great.
