Cannot generate D1Spacing in Linear Pattern
Prarthana Bataju Jul 30, 2015 6:20 AMI am trying to generate some Linear pattern in my CAD data in SolidWorks using LocalLinearPatternFeatureData with some spacing using SolidWorks API for C #. When I try to generate number of patterns using only D1TotalInstances, it works. However when I try to apply some spacing within it ... using D1Spacing, it fails though it returns true The real problem is, is display given pattern number and spacing value when I check it directly into LocalPattern I already tried rebuilding it Here is my code:
Private void ChangeLinearPatternLength ( ModelDoc2 SwModel , string StrCompPattern , double LengthMultipleVal , bool IsAdditionalNum = false )
ISelectionMgr SwSelMgr = SwModel . ISelectionManager ;
SwModel . ClearSelection2 ( true );
SwModel . Extension . SelectByID2 ( "NEC (B) _SA03-1 @ NEC_ASSY / SVKA (B) _SSA09-1 @ NEC (B) _SA03 " , "COMPONENT" , 0 , 0 , 0 , false , 0 , null , 0 );
AssemblyDoc AssDoc = ( AssemblyDoc ) SwModel ;
AssDoc . EditAssembly ();
SwModel . Extension . SelectByID2 ( "LocalLPattern1 @ NEC (B) _SA03-1 @ NEC_ASSY / NEC (B) _SSA09-1 @ NEC (B) _SA03" , "COMPPATTERN" , 0 , 0 , 0 , false , 0 , null , 0 );
Feature SwFeature = SwSelMgr . GetSelectedObject6 ( 1 , - 1 );
string StrPatterName = SwFeature . GetTypeName2 . () ToUpper ();
switch ( StrPatterName )
case "LOCALLPATTERN" :
Debug . Print ( "Linear Pattern:" + SwFeature . Name );
EruoshieilLinearPatternFeatureData LlpDefinition = default ( EruoshieilLinearPatternFeatureData );
LlpDefinition = ( EruoshieilLinearPatternFeatureData ) SwFeature . getDefinition ();
LlpDefinition . D1Spacing = ( double ) 300 / 1000 ;
LlpDefinition . D1TotalInstances = 4 ;
bool status = SwFeature . ModifyDefinition ( LlpDefinition , SwModel , null );
SwModel . FeatEdit ();
SwModel . ShowConfiguration2 ( "Default-_Flexible1" );
Break ;
Can anyone suggest me what am I missing or doing wrong here.
