How will driveworks driven part work if you put them in assembly???
Question asked by Charlie Fan on Jul 30, 2015
Latest reply on Jul 31, 2015 by David Mandl
Hi, all
I hope someone with Driveworks experience can answer my question:
I know that driveworks can autometically change lots of things for the parts. For example, it would be easy to make the rule that if a bar is more than one meter long, then it should have 3 holes; and if it is less than one meter long then it has 2 holes.
By doing this, we make a smart model that the number of holes can adapt to the length of the bar.
However, what if now I put this bar into assembly, and I modify the assembly height, and causing the bar length to change, will this automatically trigger the number of the holes on the bar to change, or do I need to open the bar part file and run the driveworks manually to change it?
Thank you for your help.
