Hello All...
I am trying to use scan data from existing parts with very little luck so far. The first *.stl data file was produced using a light (laser) scanning faro arm. The file is 57MBytes, 1.16milion faces. I have tried importing directly into SolidWorks. I can see it as a graphical entity but I need to make measurements so that I can mate parts to it.
I then tried using Scan to 3d (I have an up to date Premium license) it stalled, suggesting I import the file as a graphical entity.
I have also tried Meshlab. The file opens and I can save it as a *.dxf but am then unable to import it into SolidWorks.
And Rhino..am able to see it again but not able to save it into any format.
Does anyone have any pointers?
I don't have Scan to 3d in my license.
SolidWorks can import about 15,000 - 20,000 triangles as a solid body, and slightly more as a surface body. Large files like the 1 million triangles you have now can only be imported as a graphics body. It sounds like you figured that out.
I use graphics bodies a lot to reverse engineer parts in SolidWorks from scans. Its a pain that you can't snap to scans or get sections from scans in SolidWorks, but there are ways around this.
I have used other applications to generate contours from a scan at specific intervals, and save as an IGS file. Then the contours can be imported as 3d sketches or curves.
Usually, I cut the scan up in several places, especially where I want sections, and then create planes or sketches in SolidWorks at those locations, and trace over the scan.
