I was wondering if there is a way to link two of the same drawings that are saved in separate folders so that if you change one of the drawings the other drawing will update too?
Example:
C: -> Solidwork Files -> Enclosure with wheels -> Part 1.slddrw
C: -> Solidwork Files -> Enclosure without wheels -> Part 1.slddrw
What I want to be able to do is...
If I added a note to something in Part 1.slddrw under enclosure with wheels folder the Part 1.slddrw under enclosure without wheels folder would add that same note.
Mike
I do not know of a way to do that between drawings. If you added the note as an annotation to the model such that it would show in a particular configuration and then had that view on the drawing import that annotation it might approximate what you are looking for. In general, the info on a drawing pulls info from the model, not other drawings.
