I'm making a sliding door assembly, the opening width can be specified by increment of 1mm.
Some components such as the glass panel depends directly on the opening size,
while components such as tracks can cover a range, e.g. 2000mm track for opening of 900-1000mm, 2200mm track for opening of 1000-1100mm and so on...
So, is it possible to set up my model so that i can control everything (Glass size, track length configuration, etc) by one variable (my opening width)?
Or do I have to setup multiple configurations in my parent assembly and choose manually, and then enter my opening width as a separate variable?
Thanks for your help.
EDIT: SWK 2014 SP4.0
A quick thought would say Yes you can. But again I would like to know what final outputs you would be looking for?
Separate files based on the width factor? If yes then DriveWorksXpress is the best tool you need
Same file but multiple configuration? Configuration Publisher
