i have a drawing with dimension a lot, and i dont wanna have a drawing with thousand dimension in one view.
then I need the same view in different sheets, but is very difficult to put it in the same place... and when translate my drawing on PDF format this desfase is very evident.
Eduardo,
Instead of copying just the one view you can copy the sheet. This will make sure each sheet is exactly the same. You can then just delete the dimensions and views you don't need. I would use detail views of specific areas of the original view though. Several sheets with the same view and different areas dimensioned could get confusing.
Cheers,
Derek
