I need to know the x and y coordinates of holes located on a curve. The holes are created with a curve driven pattern.
I cannot export the x and y coordinate from a sideview into the hole table.
From a topview I cannot export the first two x coordinates but the rest afterwards can be exported. I am not sure if the hole location is accurate enough, due to the warning message. (images attached)
I appreciate any help.
With the method shown in the listed video you can extract the xyz coordinates from a 3-D sketch. I tried it. It is noteworthy that the order of the points listed in the table depends on the order you made the points in your sketch. Create an extra point in the beginning coincides with the reference location you want to have. When the table is created you can subtract the point coordinates from all the other coordinates to have to correct location.
Extracting XYZ Point Data - YouTube
