Hi
I am trying to figure out how I can create some sort of assembly BOM showing when a part is used in more than one assembly.
So for example I have part 'A' and it is used 4 times in assembly 01.
Part 'A' is then used in Assembly 02, 3 times.
Now when I create a component sketch for part 'A' I want to have a box that shows: -
The assembly mark where it was used and the quantities in each assembly. Then the total used in all assemblies 7 in total.
This way I don't have to keep making component sketches for the same part but in different assemblies.
An example is shown below, where the part marked P8239 has 2 required on assemblies 40600, 40602, 40603.
This give a total of 6 parts required marked P8239 wanted in total.
How would I set this up?
Mark (SolidWorks 2015 sp4)
Hi
I don't want to bump this thread, but does no one have a solution / work around for this?
I can't be the only one who has this issue.
I am also sending off to my VAR to see if they have a solution.
Regards
Mark
