10 Replies Latest reply on Dec 7, 2015 4:46 PM by Arthur McRae
    macro replace chain of splines
    Arthur McRae
      So I work in the sign industry and get sent dxf files from our graphic designers. Often they contain splines. My problem is I've set up parametric parts and assemblies based on a copied dxf sketch, when the graphic designers do a revision, scale etc I have to basically start over selecting every imported spline and replacing with the new.  I've used excel macros a bit and know how powerful they can be but I don't even have a clue where to start with this. Help.
           Is there anyone out there able to help me get started? I'd love to be able to select chain I want to replace with then select chain on the original.  The spline counts will be the same, the same placement in relation to one another but often scaled.  Let me know if you need any more information on my dilemma.
      Thanks so very much for any time you spend on this;
      Arthur
        • Re: macro replace chain of splines
          Feroz Mahomed
          Arthur,
          Can you post a sample dxf file with splines? I want to test the fit spline function.
              Arthur McRae
              Here you are, this is how I receive the file from the graphic designers.  I haven't removed the leader lines that have become extra line segments like I normally do before importing to SolidWorks.
                  Feroz Mahomed
                  Arthur,
                  Attached is a macro I use to select all splines.
                  I sometimes get splines in my sketches when I use the convert entity function. I replace the spline manually by creating a tangent arc. I then use the macro to select all splines and then delete them. Please note that the macro only selects all splines in the active sketch.Deleting would have to be done manually.
                      Arthur McRae
                      The approach I was trying to take (not having any luck with) was have active sketch, prompt select chain, recording splines in array, select second chain, user check message that chain was selected from same place, use replace entity with each point in the array.  I can't get any of it to debug properly. I'm not sure if I'm taking the correct approach or if what I'm attempting is impossible. I'm still new at learning the SolidWorks API library.
                      Also checked the file I uploaded, just realized that particular file is all polylines not splines
                    Arthur McRae
                    So after discovering that I uploaded an inaccurate example I was given this. A literal example. I was give these files made a bent aluminium sheet pan with a cut out of the letters, I then make a plastic letter with a flange and place it in the cut out. I was then given the second file with resizing, right now my only option is having to go  back through the entire process of doing my offsets on each letter again offset the push thru .125  and the flange .625 from the original again. I discovered that by selecting and using the replace entity tool none of my previous work is messed up. The problem with that is on the more complicated letters that requires allot of clicking each separate piece.
                    Arthur McRae
                    So my thought process (nothing is working yet) for the macro is this:
                    check that sketch is open
                    prompt to select chain to be replaced (can't figure this out at all)
                    save selection in order as array
                    prompt to select chain to keep
                    save to next column in array
                    run replace entities through array
                    ask if want to run macro on another chain (not sure how to code this either)
                    I have checked that in scaled chains that the chain selection order is always the same.
                    Deepak Gupta I know you have created some beautiful macros, can you help?
                      Arthur McRae
                      here is what I've gotten so far.
                      I can't get the replace sketch function to properly work
                      Dim swDoc As SldWorks.ModelDoc2
                      Dim swSketch As SldWorks.Sketch
                      Dim SelMgr As SldWorks.SelectionMgr
                      Dim sketchSegment As SldWorks.sketchSegment
                      Dim SelData As SldWorks.SelectData
                      Dim SelectCount As Long
                      Dim boolstatus As Boolean
                      Dim check As Boolean
                      Dim iReply As String
                      Dim vSegs As Variant
                      Dim vSeg As Variant
                      Dim swSeg As SldWorks.sketchSegment
                      Set swDoc = swApp.ActiveDoc
                      Set swSketch = swDoc.SketchManager.ActiveSketch
                      iReply = "WARNING! Macro underdevelopment"
                      MsgBox iReply
                      'check that sketch active
                      If swSketch Is Nothing Then
                          MsgBox "No sketch active!"
                          Exit Sub
                      'select chains
                      Dim I As Integer
                      Dim N As Integer
                      Dim CountCheck As Variant
                      ReDim CountCheck(1)
                      check = False
                          While check = False
                              For I = 0 To 1
                              vSeg = ChainSelector(I)
                              CountCheck(I) = SelectCount
                              If I = 0 Then
                              ReDim vSegs(UBound(vSeg), 1)
                              Else
                                  ' error message
                                  If Not CountCheck(0) = CountCheck(1) Then
                                  iReply = "Selected chains do not contain same number of entities " & _
                                  CountCheck(0) & " V.S. " & CountCheck(1) & vbCrLf
                                  MsgBox iReply
                                  Else
                                  check = True
                              If I = 0 Or check = True Then
                              For N = 0 To SelectCount
                              Set vSegs(N, I) = vSeg(N)
                              Next N
                              Next I
                          Wend
                      ' replace first array with second
                      For I = 0 To SelectCount
                      boolstatus = seg_replace(vSegs(I, 0), vSegs(I, 1))
                      If boolstatus = False Then
                      iReply = "ERROR" & vbCrLf & "Replace failed." & vbCrLf
                      MsgBox iReply
                      End
                      Next I
                      Function ChainSelector(I As Integer) As Variant
                      Dim swFrame As SldWorks.Frame
                      Dim C As Integer
                      Set SelMgr = swDoc.SelectionManager
                      Set SelData = SelMgr.CreateSelectData
                      Set swFrame = swApp.Frame ' set status bar variable
                      Segment_Check: 'return point if not sketch segment
                      'clear selection to start
                      swDoc.ClearSelection2 True
                      'boolstatus = swApp.SetSelectionFilter("SKETCHSEGMENT", True)
                              ' loop count message
                              If I = 0 Then
                              iReply = "Select member from chain to be replaced.    " & vbCrLf
                              MsgBox iReply
                              Else
                                  If I = 1 Then
                                  iReply = "Select member from static chain.    " & vbCrLf
                                  MsgBox iReply
                              Else
                              iReply = "Incorrect loop count." & vbCrLf & "ERROR" & vbCrLf
                              MsgBox iReply
                              Return
                      ' Wait While/Wend
                          While SelMgr.GetSelectedObjectCount2(-1) < 1
                            DoEvents
                            swFrame.SetStatusBarText "Please select sketch segment." ' feed status message to status bar
                          Wend
                              ' object type check
                              Dim selObject As Object
                              Dim selectByString As String
                              Dim objectTypeStr As String
                              Dim objectTypeInt As Long
                              ' Get the selection specification of the first selected object
                              Set selObject = SelMgr.GetSelectedObject6(1, -1)
                              SelMgr.GetSelectByIdSpecification selObject, selectByString, objectTypeStr, objectTypeInt
                              'Debug.Print "Name of selected feature: " & selectByString
                              'Debug.Print "Type of object: " & objectTypeStr
                              'Debug.Print "Type of object as defined in swSelectType_e: " & objectTypeInt
                              If Not objectTypeStr = "SKETCHSEGMENT" Then
                              GoTo Segment_Check
                      Set swSeg = SelMgr.GetSelectedObject6(1, -1)
                      ' select chain
                      boolstatus = swSeg.SelectChain(False, Nothing)
                      ' Response to selection
                          iReply = SelMgr.GetSelectedObjectCount2(-1) & " item(s) selected.   " & vbCrLf
                          MsgBox iReply
                      ' Save selection to array
                      SelectCount = 0 ' zero counter
                      SelectCount = SelMgr.GetSelectedObjectCount2(-1) 'select regardless to mark
                      SelectCount = SelectCount - 1
                      ReDim vSeg(SelectCount)
                          For C = 0 To SelectCount
                              Set vSeg(C) = SelMgr.GetSelectedObject6(C + 1, -1)
                          Next
                          ChainSelector = vSeg
                          swFrame.SetStatusBarText "Done" ' feed done message to status bar
                      End Function
                      Function seg_replace(seg1 As Variant, seg2 As Variant) As Boolean
                      SelMgr.GetSelectByIdSpecification seg1, selectByString, objectTypeStr, objectTypeInt
                      SelMgr.GetSelectByIdSpecification seg2, selectByString, objectTypeStr, objectTypeInt
                      boolstatus = swDoc.SketchManager.SketchReplace(False)
                      seg_replace = boolstatus
                      End Function
                        Arthur McRae
                        Finally got my Macro working, it is attached.  Figured out where I went wrong in a couple places.  Let me know if you end up using it or parts of it's code I'd be interested in seeing what you've done too.  I wanted to do some better forms but seeing as this is literally my second vba project I'm pleased with what I've accomplished.
