Hi everyone,
I need a macro to change component name with component description..
I found this code but for the moment i don't know how to modify it
Option Explicit
Set swModel = swApp.ActiveDoc
Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, 0)
If swComp Is Nothing Then
Debug.Print "Select a component and run the macro again."
Exit Sub
Else
' swUserPreferenceToggle_e.swExtRefUpdateCompNames must be set to
' False to change the name of a component using IComponent2::Name2
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swExtRefUpdateCompNames, False
' Print original name of component
Debug.Print (" Original name of component = " & swComp.Name2)
' Change name of component
swComp.Name2 = "SW"
' Print new name of component
Debug.Print (" New name of component = " & swComp.Name2)
For example:
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("Default")
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("DefaultSM-FLAT-PATTERN")
Alternatively, if you want to set the component's name as the active configuration's description, you can use this:
Set swCustPropMgr = swModel.Extension.CustomPropertyManager(swComp.ReferencedConfiguration)
