How can I use a property ReverseDirection in a swRefPlaneConstraintBase?
Question asked by Erika Gómez on Jul 23, 2015
Latest reply on Aug 4, 2015 by Erika Gómez
How can I use a property ReverseDirection in a plane wich IRefPlaneFeatureData::Type2 returns swRefPlaneConstraintBase and IRefPlaneFeatureData::Type returns swRefPlaneDistance?
In the API help says that a property ReverseDirection can be used in a Constraint-based with angle or offset distance references, but when I assign a new value to the property it doesn't change.
In my code I have
     bool reverse;
     reverse = true;
     MyPlaneRef.ReverseDirection  = reverse
But when I check the values after to execute the above code the objet return ReverseDirection: false, what should I do to that property can change?
MyPlaneRef
Objeto COM
    [System.__ComObject]: Objeto COM
    Angle: 0.0
    AutoSize: false
    Distance: 0.01
    OriginOnCurve: false
    ProjectionType: 0
    Selections: {object[1]}
    SolutionIndex: 0
    Type: 5
    Type2: 11
    UseNormalPlane: false
