Please help, i'd like to think I was nearly there but need a little help.
Im trying to model some steel mesh reinforcement inside a concrete block. I've manage to create an 'L' shaped rod at one end and I would like to repeat this multiple times running up the unit to 50mm inset from the back face. As you see the unit is angled and reduces in height slightly so my reinforcement will have to reduce too. I intend to place horizontal bars to create the mesh effect (an tips on how to do this also would be greatly appreciated).
If anyone has an easier suggestion I'd be happy to take any advice.
Many thanks
Lee
I am on SW2014 so I couldn't open your file, so I am only guessing at what you are trying to do based on your description. It sounds to me like you want to use a linear pattern with the Vary Sketch option checked, so that the sketch for the bar will adjust based on the geometry changes along the pattern. See if my example file gives you any inspiration.
