I have merged two macro's together and now it saves all open as a pdf building the file name from values of the referenced model in the drawing file then closes the document.
I am having trouble ending the loop where the macro runs through the drawing and everything I try I get the following error;
I have since deleted anything that trys to end the loop to test the rest of the macro and it works great! It just crashes at the end when there is no open document!
Can someone help me end this loop in the macro?
Your help would be greatly appreciated!!! (see macro below)
_____________________________________________________________________
Dim swCustProp As CustomPropertyManager
Dim valOut1 As String
Dim valOut2 As String
Dim resolvedValOut1 As String
Dim resolvedValOut2 As String
Dim Filepath As String
Dim ConfigName As String
Dim PartNo As String
Dim FullName As String
Dim nFileName As String
swDocs = swApp.GetDocuments
For i = 0 To UBound(swDocs)
Set Part = swDocs(i)
Set swDraw = swApp.ActiveDoc
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
If (swModel.GetType = swDocPART) Then
ConfigName = swView.ReferencedConfiguration
FullName = swModel.GetTitle
PartNo = Left(FullName, Len(FullName) - 7)
'Filepath = "C:\Users\m.jones\Desktop\PDF\"
Set swCustProp = swModel.Extension.CustomPropertyManager(ConfigName)
swCustProp.Get2 "Description", valOut1, resolvedValOut1
swCustProp.Get2 "Revision", valOut2, resolvedValOut2
nFileName = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\")) & PartNo & "-" & ConfigName & "-" & resolvedValOut2 & " " & resolvedValOut1
swDraw.SaveAs3 nFileName & ".PDF", 0, 0
'MsgBox nFileName & ".PDF" + " Saved as a PDF"
swApp.QuitDoc swDraw.GetPathName
ElseIf (swModel.GetType = swDocASSEMBLY) Then
Set swCustProp = swModel.Extension.CustomPropertyManager("")
nFileName = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\")) & PartNo & "-" & resolvedValOut2 & " " & resolvedValOut1
Next i
