I am trying to get the result (x,y, and z coordinate) of vertical projection of two points on a knitted surface.
RayIntersections and GetRayIntersectionsPoints look promising but there no good documentation. Even on the solidworks api help website.
Attached the file I am working on and below is the script.
Could you please look at the script and tell me what is wrong with it and/or if you have a better aproche or a good documentation about how to get the coordinate of the vertical projection of the two points on the surface.
Thanks.
Dim swBody(0) As SldWorks.Body2
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
boolstatus = swModel.Extension.SelectByID2("surface", "REFSURFACE", 0, 0, 0, False, 0, Nothing, 0)
Set swBody(0) = swSelMgr.GetSelectedObject6(1, -1) ''
Dim PointsArray(5) As Double
dPtArr(0) = -1.14329
dPtArr(1) = 0.11616
dPtArr(2) = 0.0017
dPtArr(3) = -37.9361194
dPtArr(4) = -4.57
dPtArr(5) = 0.54
Dim dVecArr(2) As Double
dVecArr(0) = 0
dVecArr(1) = -1
dVecArr(2) = 0
Const hitRadius As Double = 0.0000095
Const offset As Double = 0.0000001
Dim nNoOfInterestions As Integer
Debug.Print swModel.RayIntersections(swBody, dPtArr, dVecArr, swRayPtsOptsTOPOLS, hitRadius, offset)
Dim vPts As Variant
vPts = swModel.GetRayIntersectionsPoints
