1 Reply Latest reply on Jul 21, 2015 12:49 PM by Ash Can
    Array of reference points using InsertReferencePoint
    Ash Can
      I have a spline and am trying to insert references points along the spline, convert these points to a 3d sketch and then export them.
      I have this working fine for equally distributed reference points using
      Dim UpperSplinePts As Variant
      Dim vFeat as Variant
      Dim feat as SldWorks.Feature
      UpperSplinePts = Part.FeatureManager.InsertReferencePoint(swRefPointAlongCurve, swRefPointAlongCurveEvenlyDistributed, 0#, NumPoints)
      ---Other processing code---
      For Each vFeat In UpperSplinePts
              Set feat = vFeat
              Set swRefPt = feat.GetSpecificFeature2
              Set swRefPtData = feat.GetDefinition
              Set mtPt = swRefPt.GetRefPoint
              Set swSkPt = Part.SketchManager.CreatePoint(mtPt.ArrayData(0), mtPt.ArrayData(1), mtPt.ArrayData(2))
      Next
      How ever, I am not pleased with the equal distribution and hence am now trying to insert the ref points using the "Percentage along curve " option.
      Dim UpperSplinePt     As Variant
      Dim vFeat                 As Variant
      Dim feat As SldWorks.Feature
      A = 0
      For i = 1 To NumPoints
           boolstatus = Part.Extension.SelectByID2(Spline_IDs(1), "EXTSKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0) ' Select the Spline
           percentage = Sin(A / 57.2957795130823) ^ 2 * 100
           If percentage > 100 Then percentage = 100
           UpperSplinePt = Part.FeatureManager.InsertReferencePoint(swRefPointAlongCurve, swRefPointAlongCurvePercentage, percentage, 1)
           Part.ClearSelections2 True ' Clear the selected point
           A = A + 90 / NumPoints
      Next i
      This seems fine, but I am a bit stuck as to how to build an array from the individually returned 'UpperSpinePt' to insert the 3D sketch points.
      I have tried
      UpperSplinePt(i) = Part.FeatureManager.InsertReferencePoint(swRefPointAlongCurve, swRefPointAlongCurvePercentage, percentage, 1)
      but get a type mismatch error.
      What would be the right way to do this? I basically want to build up my array of UpperSplinePts based on the pointer returned by UpperSplinePt inside this loop. Would it be possible?
        • Re: Array of reference points using InsertReferencePoint
          Ash Can
          I managed to solve it, as it was more a VBA question rather than SW API
          This is the fixed snippet!
          Dim UpperSplinePts() As SldWorks.Feature
          Dim RefSplinePt As Variant
          A = 0
          ReDim UpperSplinePts(0 To NumPoints)
              For Each RefSplinePt In UpperSplinePt
                        Set UpperSplinePts(i) = RefSplinePt
              Next RefSplinePt
          Next i
