Let's say I have an existing part, an air cylinder, and
wanted toadd a part to it such as pneumatic fittings but did not
want totake the time to draw out the part, create an assembly, and
bringin the fitting to the cylinder so that the fitting would show
up inthe BOM. Is there a way to do this such that the part
showsup in the BOM as a separate line item but I do not have to
actuallyhave it in the part or even take the time to draw it and
include itin there?
Works well if you decide to go back later and add solid geometry.
You may also look at trying this with the "Smart Component" feature so it will insert them all. Not sure if it will work with empty part files but it may.
Now insert the cylinder into any assembly. Its icon has a star on it to indicate its a smart component. Right click it and select "Insert Smart features". Now all the parts are in the assembly with the cylinder and they show in the BOM.
Thank you!
Nayshil.
