Hello
I've modeled one shape with surfaces, and i've tried to make ananalisys with FloWorks, but the problem is: when i try to use thisshape in a FloWorks analisys, the program says there must be atleast one component. It seems the program needs solidcomponents, i think. I would like someone could tell me if there isany option, or conversion tool for surfaces in order to realize aFloWorks analysis with surfaces. I've tried to transform surfacesto solids, given them thickness, but it's a hard work, and itdoesn't works because i create zero geometry, and that makesimpossible the FloWorks analisys. My specific doubt is thenext:
- I've modeled with surfaces, does exists some way to
convertthe model so that it can be studied by FloWorks?
Thank you very much
Thank you very much
I know this can be a hard work, but you have to use solid bodies...
