In the Event properties for a part or assembly you can link files, websites, etc to open when a user clicks on a part or custom button you set up. This would work in the Composer Player or from a exported svg file.
If you are talking about just a link directly in your file I am not sure that is possible.
Please tell me which software version of Adobe reader you are using to open that pdf (if you are using adobe) and where is the location of that pdf in your system. As it is working fine in my system here.
You can use a 2D image and you can link to any pdf file. Then you need to PICK the design mode. The Pdf file what ever you linked it will be open while clicking that 2D image in animation mode.
Cheers,
Derek
