Merging Two Macros?
Question asked by Matt Jones on Jul 21, 2015
Latest reply on Jul 21, 2015 by Deepak Gupta
Hey Guys
So I have written a macro (a combo of what I have learnt in the limited VBA/API time I have been learning this stuff and mixing it with the code you guys have in the forums) that saves a drawing document as a PDF and builds the name out of info from the model referenced in the drawing document.
I also have a different macro that saves all open documents as a PDF just with the filename of the drawing then closes them.
I am trying to merge these two macros together so basically save all open documents as a PDF with the first macro then closes the documents. But I cant get it to work, it either gets stuck in a loop on the one document or it saves all the open documents as the name from the first referenced model.
Does anyone know how to easily do this? I am very keen on learning this stuff but need a push in the right direction due to not being very fluent in VBA!
Here is my first Macro;
____________________________________________________________________________
Dim swCustProp As CustomPropertyManager
Dim valOut1 As String
Dim valOut2 As String
Dim resolvedValOut1 As String
Dim resolvedValOut2 As String
Dim Filepath As String
Dim ConfigName As String
Dim PartNo As String
Dim FullName As String
Set swDraw = swApp.ActiveDoc
If (swDraw Is Nothing) Or (swDraw.GetType <> swDocDRAWING) Then
Exit Sub
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
ConfigName = swView.ReferencedConfiguration
FullName = swModel.GetTitle
PartNo = Left(FullName, Len(FullName) - 7)
Filepath = "C:\Users\m.jones\Desktop\PDF\"
If (swModel.GetType = swDocPART) Then
    Set swCustProp = swModel.Extension.CustomPropertyManager(ConfigName)
    swCustProp.Get2 "Description", valOut1, resolvedValOut1
    swCustProp.Get2 "Revision", valOut2, resolvedValOut2
    swDraw.SaveAs (Filepath + PartNo + "-" + ConfigName + "-" + resolvedValOut2 + " " + resolvedValOut1 + ".PDF")
    MsgBox Filepath + PartNo + "-" + ConfigName + "-" + resolvedValOut2 + " " + resolvedValOut1 + ".PDF" + " Saved as a PDF"
ElseIf (swModel.GetType = swDocASSEMBLY) Then
    Set swCustProp = swModel.Extension.CustomPropertyManager("")
    swDraw.SaveAs (Filepath + PartNo + "-" + resolvedValOut2 + " " + resolvedValOut1 + ".PDF")
    MsgBox Filepath + PartNo + "-" + resolvedValOut2 + " " + resolvedValOut1 + ".PDF" + " Saved as a PDF"
_______________________________________________________________________________
Here is the second Macro
Dim Part As SldWorks.ModelDoc2
Dim FilePath As String
Dim Pathsize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
swDocs = swApp.GetDocuments
     For i = 0 To UBound(swDocs)
          Set Part = swDocs(i)
          If Part.GetType = swDocDRAWING Then
               FilePath = Part.GetPathName
               Pathsize = Strings.Len(FilePath)
               PathNoExtension = Strings.Left(FilePath, Pathsize - 6)
               NewFilePath = PathNoExtension & "pdf"
               Part.SaveAs2 NewFilePath, 0, True, False
               swApp.QuitDoc Part.GetTitle 'to disable auto close of doc add ' to start of this line
               MsgBox "Saved" & NewFilePath 'to get rid of message box add ' to start of this line
      Next i
