I haven't used PhotoView for about 3 months and now suddenly have two jobs that require it. When I start any of the PV360 options, a window shows up (looks correct) but lasts for only about 1sec then disappears.
Several things have changed on my PC in the mean time so I am not claiming that this problem started within SolidWorks, but I am hoping someone else has seen and fixed this problem. The VAR is also looking into the problem, but so far no luck. This is what I have done so far:
1. Upgraded from SW2015SP2 to SP 4.
2. Reinstalled graphics card driver
3. Uninstalled Bonjour, reinstalled.
4. Uninstalled Bonjour, installed I-tunes (which installs Bonjour)
5. Uninstalled SW and reinstalled.
Any advice would be appreciated.
Allen,
Did your VAR get back to you with a solution to this problem?
I have a similar issue with a laptop I use just for testing.
The preview window opens, the display is black and then disappears!
