Plate Descriptions Go To Pot After Renaming Cut List Folders
Question asked by John Lega on Jul 17, 2015
Latest reply on Jul 27, 2015 by John Lega
Good morning,
We recently upgraded to 2015 from 2014 and I am having a new issue. In the past (since 2008) we have used a rectangular profile for creating plates (weldments). The information was carried over from the rectangle profile to the Cut-List just fine (PL, “thickness” x “width”) and of course the built-in value for Length.
With 2015 – all other member types (Wide Flange, Angles, etc) work fine but the Plate profile (attached) does not produce proper information in the Cut-List (just carries over the “Value/Text Expression” UNLESS I UNCHECK "RENAME CUT LIST FOLDERS WITH DESCRIPTION PROPERTY VALUE". If I choose that option (which we want), the cut-list for plates goes to pot.
This is a big issue for us since we do a lot with plate. I’m hoping there is a fix. I did save the profile and part template in 2015 format but no go. I am attaching a sample part, out plate profile and template if anyone can help.
Example of this issue also attached.
Thanks everyone.
Regards,
John Lega
