3 Replies Latest reply on Jul 16, 2015 5:25 AM by Deepak Gupta
    How to reload sheet format?
    Yong Ning
      Reload. If you make changes to the Sheet Format, click to return to the default format.
      Sheet Format/Size
      Standard sheet size. Select a standard sheet size, or click Browse and locate a custom sheet format file.
      Display sheet format. Display border, title block, and so on.
      Why use SetTemplateName or SetupSheet4 don't reload the Sheet Format?
                     tmpPlateName = oRng
                     SwSheet.SetTemplateName tmpPlateName
                     SwDraw.SetupSheet4 SwSheet.GetName, 12, 12, 1, oScale, True, tmpPlateName, 0.42, 0.297, "Default" ', True
      Private Sub del()
         Dim Xls As Excel.Application, Rng As Range
             Set Xls = GetObject(, "Excel.Application")
             Set Rng = Xls.Selection
         Dim PathName
             PathName = Xls.ActiveWorkbook.Path & "\" & Rng
             Stop
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
             Set SwApp = Application.SldWorks
             Set SwModel = SwApp.ActiveDoc
         Dim SwSheet As Sheet
              Set swDraw = SwModel
              Set SwSheet = swDraw.GetCurrentSheet
              vSheetProps = SwSheet.GetProperties
              SwModel.SetupSheet5 SwSheet.GetName, swDwgPapersUserDefined, swDwgTemplateCustom, _
                     vSheetProps(2), vSheetProps(3), False, PathName, 0.42, 0.297, "Default", True
              swDraw.ForceRebuild3 False
          • Re: How to reload sheet format?
            Yong Ning
            key code?
            Reload Sheet Format | SOLIDWORKS Forums
            https://forum.solidworks.com/message/477234#477234
            Sub TraverseEditTemplate0716()
               Dim PDFApp As New AcroApp, PDF1 As New AcroPDDoc, PDF2 As New AcroPDDoc
               Dim E As Long, W As Long, PDFFile
               Debug.Print Time
               Dim FinishTime, Txt, T: T = Timer
                  Txt = Time
               Dim AsmFile, oArr, MergePDF
                  AsmFile = Rng(0, 1)
                  FinishTime = Rng(0, 2)
                  MergePDF = Rng(0, 3)
               Dim oRng As Range, PDFRng As Range
               Dim R1 As Range, R2 As Range, R3 As Range, R4 As Range
               Dim R5 As Range, R6 As Range, R7 As Range
                  Set R1 = Xls.Range(Rng(1, 1))
                  Set R2 = Xls.Range(Rng(2, 1))
                  Set R3 = Xls.Range(Rng(3, 1))
                  Set R4 = Xls.Range(Rng(4, 1))
                  Set R5 = Xls.Range(Rng(5, 1))
               Dim RegExp As New RegExp, oRegExp As New RegExp, Str
                  For ii = 1 To R4.Rows.Count
                     If R4(ii, 1) <> "" Then
                       Str = Str & R4(ii, 1) & "|"
                  Next ii
                  RegExp.Pattern = Left(Str, Len(Str) - 1)
                  For ii = 1 To R5.Rows.Count
                     If R5(ii, 1) <> "" Then
                       Str = Str & R5(ii, 1) & "|"
                  Next ii
                  oRegExp.Pattern = Left(Str, Len(Str) - 1)
                  Debug.Print oRegExp.Pattern
                  'Set R6 = Xls.Range(Rng(6, 1))
                  Set R7 = Xls.Range(Rng(7, 1))
               Dim xyRng As Range
               Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
                  SwApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchInference, False
               Dim SwLayerMgr As LayerMgr, tmpPlateName
               Dim Xx1, Yy1, Xx2, Yy2, Xx3, Yy3, Xx4, Yy4
               Dim vSheet, SwSheet As Sheet, ConfName, View1, X1, Y1, View2, X2, Y2, oScale As Double
               Dim SwView As View
               For kk = R1.Rows.Count To 1 Step -1
                  Set SwModel = SwOpenFile(SwApp, R1(kk, 1))
                  Set SwLayerMgr = SwModel.GetLayerManager
                  Set xyRng = R7(kk, 1).Resize(1, R7.Columns.Count)
                  'Debug.Print kk, SwModel.GetTitle,
                  Set SwDraw = SwModel
                  With SwDraw
                     vSheet = .GetSheetNames
                     For jj = UBound(vSheet) To 0 Step -1
                        If R2(kk, jj + 1) <> "-" Then
                           'Debug.Print R2(kk, jj + 1), R2(kk, jj + 1).Address
                           Set oRng = Xls.Range(R2(kk, jj + 1))
                           'Debug.Print oRng.Address, oRng.Parent.Name
            '              Debug.Print oRng.Areas(7).Address, oRng.Areas(7)
                           oScale = oRng.Areas(7)
                           .ActivateSheet vSheet(jj)
                           Set SwView = SwDraw.GetFirstView
                              Do While Not SwView Is Nothing
                              If jj = 0 Then
                                 RegExpDelDim SwModel, SwView, RegExp
                              Else
                                 RegExpDelDim SwModel, SwView, oRegExp
                              Set SwView = SwView.GetNextView
                           Loop
                           Set SwSheet = .GetCurrentSheet
                           'SwSheet.SetScale 1, oScale, False, False
                           If jj <= 3 Then
                              Set oRng = R3(1, jj + 1)
                           Else
                              Str = "Rib" & Split(SwSheet.GetName, "筋板")(1)
                              Set oRng = R3.Find(What:=Str, LookIn:=xlValues)
                           tmpPlateName = "E:\Drawing\SldDrt\t.slddrt"
                           SwDraw.SetupSheet4 SwSheet.GetName, 12, 12, 1, 1, True, tmpPlateName, 0.42, 0.297, "" ', True
                           SwModel.ViewZoomtofit
                           SwModel.ForceRebuild3 False
                           'Stop
                           tmpPlateName = oRng
                           'SwSheet.SetTemplateName tmpPlateName
                           'Debug.Print SwSheet.GetName, tmpPlateName
                           SwModel.EditSketch
                           'Stop
                           EditTemplateCreateLine SwDraw, xyRng, SwLayerMgr
                           SwModel.ForceRebuild3 True
                     Next jj
                  End With
                  'Stop
                  SwModel.Save
                  Debug.Print SwModel.GetTitle,
                  SwApp.CloseDoc SwModel.GetTitle
                  PrintTiming T
               Next kk
            Private Sub ll()
               Dim TemplateName
                  TemplateName = Rng
               Dim SwDraw As DrawingDoc
               Dim vSheet, SwSheet As Sheet, Pp
                 vSheet = SwDraw.GetSheetNames
                 For ii = UBound(vSheet) To 0 Step -1
                     SwDraw.ActivateSheet vSheet(ii)
                     Set SwSheet = SwDraw.GetCurrentSheet
                     Pp = SwSheet.GetProperties
                     'SwDraw.SetupSheet SwSheet.GetName, swDwgPaperBsize, TemplateName, Pp(2), Pp(3)
                     SwDraw.SetupSheet4 SwSheet.GetName, 12, 12, Pp(2), Pp(3), True, TemplateName, 0.42, 0.297, "" ', True
                     SwDraw.EditSheet
                 Next ii
