Automatic Macro Recording?
Question asked by Todd Carpenter on Jul 15, 2015
Latest reply on Jun 17, 2016 by Neil Jackson
I've got an assembly with a design table attached, several equations, and custom properties associated with it.  All of a sudden, when opening the assembly, I get a VBA Macro  Type mismatch error.  I'm guessing this has something to do with the design tables/equations/custom properties but I'm not sure where this macro is coming from - if you notice the date, that happens every time.  I can't find where SolidWorks is being told to do this - can somebody tell me where I would look?  I'm particularly confused by the "No output File...", but this is what makes me think it's something to do with the design table.  Here's the macro it tries to record, and the line it errors on is EvaluateDouble = "2.Part" - 5th line from the bottom:
' No output File - macro recorded on 07/15/15 by tcarpenter
Option Explicit
Private Declare PtrSafe Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (hpvDest As Any, hpvSource As Any, ByVal cbCopy As Long)
Private pi As Double
Dim Part As Object
Dim Assembly As Object
Dim swApp As Object
Function vbStringFromByteArray(ByRef arr) As String
   Dim numbytes, i
   numbytes = UBound(arr) + 1
   Dim byteArray() As Byte
   ReDim byteArray(numbytes)
   For i = 0 To numbytes - 1
      byteArray(i) = arr(i)
   Next i
   vbStringFromByteArray = String$(numbytes / 2 - 1, 0)
   CopyMemory ByVal StrPtr(vbStringFromByteArray), byteArray(0), numbytes
End Function
On Error GoTo errorHandlerSW
EvaluationError = 0
   Dim modelName As String ' C:\TDCI3D\Fabco\L_S.SLDASM
   modelName = vbStringFromByteArray(Array(67, 0, 58, 0, 92, 0, 84, 0, 68, 0, 67, 0, 73, 0, 51, 0, 68, 0, 92, 0, 70, 0, 97, 0, 98, 0, 99, 0, 111, 0, 92, 0, 76, 0, 95, 0, 83, 0, 46, 0, 83, 0, 76, 0, 68, 0, 65, 0, 83, 0, 77, 0, 0, 0))
pi = 4 * Atn(1)
Set Assembly = swApp.ActiveDoc
If Assembly.GetType = 2 Then Set Assembly = Assembly.GetEditTarget
If Assembly.GetType = 3 Then Set Assembly = swApp.GetOpenDocumentByName(modelName)
Dim PartName As String
If Assembly.GetPathName <> "" Then PartName = Assembly.GetPathName Else PartName = Assembly.GetTitle
If Assembly.IsEditingSelf And PartName <> modelName Then Set Assembly = swApp.GetOpenDocumentByName(modelName)
Exit Sub
errorHandlerSW:
Evaluation
Error = Err.Number
