Through our design process there are times when we want to transition a lot of data, and times when just one part or assembly would be transitioned. Is there a way to manage what gets selected when a transition is initiated? For instances our process has a an initiated state, then an assembly and all of its parts got to a checking state, then to released. But if a part from the assembly gets revised the assembly goes into a revision loop, and possibly one part from the assembly, but not all of the assemblies parts, so I would like to select all referenced documents for the move from initiated to checking, and checking to released, but only the selected files for a move from released to revised...? Right now we select all referenced documents by default, so when a user instates a revision, if they don't un-check all of the parts it makes a pretty big mess (a bunch of necessary revised parts). Does anyone know of a good way to set this up?
Hi Aaron,
I presume that you know that there is an option on groups/user settings that let you set that references are not marked by default on transitions.
So, if you check this option only the selected files in explorer are marked for transition.
