What are the common ways to create a BOM?
What is the easiest?
What is the most comprehensive?
Can the answer come with a valium please?
Thank you.
Thank you.
That sounds crazy. From a simple drawing of a part? You _can_ override the qty property, so maybe it's messed up and buried in a part/assy configuration specific custom property? OR it could be the BOM itself has been changed. You can add values to the BOM.
I'd try the same approach with a very basic assembly/drawing, then add a basic BOM and see what happens.
Make a drawing, insert a view, R-click on view->Insert->Tables->BOM
Then start messing w/ custom properties, formats, etc. and saving out your own BOMs.
