So for years I've had a drawing setup with custom properties. Client, Project name, #, Description, etc.
With SW 2015, I'm having an issue where the "Description" property is disappearing from the Drawing.
For example, I'm working on a "IPAD TABLE" drawing:
-"IPAD TABLE" is the description I put into the "File Properties" box, next to Description.
-Then it shows up in my sheet format, at the top of every page. I have a linked Description value there in the sheet format.
This setup has worked fine for years, but has changed with the switch to SW 2015. The new problem is that the description is now disappearing.
-When I save to PDF, the PDF pops up, with the Description removed from the page:
*Also, the Description is gone from "File Properties":
What am I missing?
Hi Eric,
I think the problem is your sldproperthandler.dll is not properly installed, and so the description isn't saving when you copy or save as a file, then it isn't in the custom properties and uploading properly.
Try this thread: Re: Description in the 'save' and 'save as' dialog box disappeared.
