Hi
I'm trying to create a small plastic part with uniform thickness. My issue is that even when I set the shell thickness to 1mm, the thickness isn't uniform because of the sharp bends. Does anyone know what the proper way for setting uniform thickness is?
Here's my part:
You could try a very small internal radius applied to the inside of the part. This would then shell correctly.
