2 Replies Latest reply on Jul 14, 2015 6:20 AM by Hrituc Alexandru
    Cosmetic Threads
    Hrituc Alexandru
      HI,
      How can find the number of Cosmetic Threads from a part???  I need a macro to sum up all and add a properties with the result..
      If is not possible, then how can I add a search filter in the attached macro?
      I want to look in the search for cosmetic thread, to extract the max number from the tail and add  a property with him!.....Those are the steps that I was thinking!
        • Re: Cosmetic Threads
          Padaka Lingam
          Hi Hrituc,
               the below changes would works for requirements
          i changed the textbox into listbox for showing the list of cosmetic threads.
          i hope this will helpful for u
          ''module code
          Public swApp As SldWorks.SldWorks
          Public swMathUtility As SldWorks.MathUtility
          Public myModel As SldWorks.ModelDoc2
          Public thisFeature As SldWorks.Feature
          Public thisSubFeature As SldWorks.Feature
          Public count As Integer
              UserForm.Show
          ''form code
          Private Sub cmdExit_Click()
              End
          Private Sub cmdExport_Click()
              Dim featureText As String
              featureText = ""
              For i = 0 To ListBox1.ListCount - 1
                  featureText = featureText & ListBox1.List(i) & "," & vbCr
              Next i
              Dim filePath As String
              filePath = txtFileOutput.Text + " List features.csv"
              Open filePath For Output As #1
                  Print #1, featureText
              Close #1
              MsgBox ("Exported")
          Private Sub cmdGetFeatureList_Click()
              Set swMathUtility = swApp.GetMathUtility()
              Set myModel = swApp.ActiveDoc
              myModel.ClearSelection2 True
              count = 0
              ' Traverse features and subfeatures of this model and look for cosmetic threads
              Set thisFeature = myModel.FirstFeature
              While Not thisFeature Is Nothing
                  Debug.Print "Processing " & thisFeature.Name
                  Set thisSubFeature = thisFeature.GetFirstSubFeature()
                  While Not thisSubFeature Is Nothing
                      Debug.Print "   Processing sub " & thisSubFeature.Name
                      If (thisSubFeature.GetTypeName() = "CosmeticThread") Then
                          count = count + 1
                          ListBox1.AddItem thisSubFeature.GetNameForSelection(thisSubFeature.GetTypeName), count - 1
                      Set thisSubFeature = thisSubFeature.GetNextSubFeature()
                  Wend
                  Set thisFeature = thisFeature.GetNextFeature()
              Wend
              Hrituc Alexandru
              HI Lingam
              1. The macro works fine but I would like to ask you it's possible to give me the total of it?...  Or a numbering from wich decrease of those suppressed
              2. How can put the > supressed < if the thread is supressed?
              if it's possible i will make 11-1 (supressed) =10 and with this 10 i will make a properties
