Hi...i'm new to Solidworks.
I'm looking to design a circle extruded to a cylinder but divided into 8 parts.
The radius of the cylinder is 40mm and height is 8mm, and each division is going to be 45 degrees each.
How do i do that?
How do i do that?
Hi Alin,
Thanks for replying. I did the extrusion of the 1/8th pie and performed a circular pattern but it gives me a warning.
Here's what i mean.
Thanks Alin Vargatu
Regards
Hi @Erik
I have just followed your instruction and i had these.
But i would like to make the cylinder look split like the image below but into 8 divisions. So. i can select a part and check the coordinates of just that part. Would it be feasible to send a sldpart as well?
Thanks a lot for replying @erik
Jackie Yip thank you so much. I tried using this method to work on something similar but i have failed.
Its a similar circle with 80mm diameter extruded to a height of 8mm but sliced into 14 parts such that it looks like the figure below.
How do i go about that?
Is it possible to send an sldpart as well.
You can do it many different ways. Let's start with 2 suggestions.
1. Extrude a 1/8th pie and perform a circular pattern of bodies
2. Extrude one full cylinder and split it in 8 pieces.
