Dear All,
Right now i created one Sheet format for SW2015 but same format i need for SW2014.
Is there any quickest way to convert it in lower version (2015 to 2014)?
Regards,
Ketan
NO direct way. So save as DWG/DXF from 2015 and then import into 2014. Redo the links and fix other stuff.
You might want to try to copy in 2015 and then paste in 2014.
FeatureWorks my friend :-)
EDIT: Nvm you said sheet format, not sheet metal
Thanks Deepak,
i already tried couple of option but i did not succeeded in to that.
But solid works needs to think about it in new functionality.
I had done that successfully in the past.
