How come I can only view some documents as a PDF and others I cant? we have the "save as pdf tab checked "
Hi Shaine,
Did you turn the option on for pdfs in the vault at the very beginning of its use or at a later point in time, as the pdf files are only created when the SolidWorks drawing files are checked into the vault it doesn't create a pdf for any other type of file. If the option was only turned on after some files were added to the vault these early files will not have a pdf.
You can use the SolidWorks Task Scheduler and the "Export Workgroup PDM files" function to create the missing pdf files in the vault.
Hi Shaine,
