Hi, I am working on a V6 engine from this video: https://youtu.be/Bp2Cc_iriWM?list=PLfP1GxQ1lPaSWOY7biDuGwAnmmQplrREZ&t=989
I need to set up cam mates with a number of rocker arms like this : http://puu.sh/iQhWS/7f6158a365.jpg
The first one works perfectly, but upon as the cam shaft rotates, the rocker arms after the first one keep going UNDER the cam shaft for some reason: http://puu.sh/iQi43/035a35db4a.jpg
This is the zip file: https://drive.google.com/open?id=0B2oiT5d2gFWaZGlUQ0FDZ1JiRDQ[4]
The assembly file's name is FINAL ENGINE.
My understanding of the cam mate is that it is representative but not exact. Hopefully that will be good for your use. For instance a follower of a larger radius will not 'step' from high point to high point of a smaller radius path.
