2 Replies Latest reply on Jul 7, 2015 9:06 AM by Thomas Nagy-Zambo
    PMP Control Interfaces
    Thomas Nagy-Zambo
      I'm trying to get access to the members exposed by IPropertyManagerPageControl: 2015 SOLIDWORKS API Help - IPropertyManagerPageControl Interface Members
      AND the members exposed by IPropertyManagerPageTextbox: 2015 SOLIDWORKS API Help - IPropertyManagerPageTextbox Interface Members  for the SAME textbox.
      Essentially I need to be able to change the .Top parameter and the .Text parameter but they are under different interfaces.
      Any help would be appreciated, I am working in c#.
      Thanks.
        • Re: PMP Control Interfaces
          Simon Turner
          You can declare a variable of type PropertyManagerPageControl and set it to a PropertyManagerPageTextBox. Then you can use both sets of methods.
          E.g.
          Dim myTextBox as PropertyManagerPageTextBox
          Dim myPropCtrl as PropertyManagerPageControl
          Set myTextBox = 'enter your code to create the text box here
          Set myPropCtrl = myTextBox
          myPropCtrl.Top = 100
              Thomas Nagy-Zambo
              Thanks! Here is the working c# code for anyone who needs it:
              IPropertyManagerPageControl pmpControl;
              IPropertyManagerPageTextbox textbox1;
              textbox1 = (IPropertyManagerPageTextbox)group2.AddControl(textbox1ID, controlType, "string", align, options, "string");
              pmpControl = (IPropertyManagerPageControl)textbox1;
              pmpControl.Top = 10;
              textbox1.Text = "different string";
