I have been testing SW Inspection for our company, it was very interesting, but I would like to know if there the possibility when you export the inspecton to excel template that the items are 1,2,3.. instead of 1.1, 1.2, 1.3 it normally happens when the drawing has notes, it is because we have to type numbers sequentially according to the procedures.
This is the property that I used:
iex:INSPECTIONXPERT/SAMPLE_SHEET/CAD/ATTRIBUTES/ATTRIBUTE[@selected='true']/@prefix
Hi Diorella,
You can try 2 things:
NOT auto Explode the note.
What you will have is just 1 balloon for the note and all the information in one cell.
OR
You can export your project to an *.ixprj and then change the balloon number from 1.1,1.2, ... to 1,2,3 for the note using the Grouping options.
that should take just a minute or two and you will have exactly what you want.
FYI: You can see this in the Quick Start Guide
