I regularly have to place parts in assemblies that have a max distance between them. ie: 70" between gussets, 48" between spacer bars, 72" between hinges.
So far if I set up parametric conditions and then change them I have to manually change the linear pattern spacing and instances every time. I've searched the forum and I've seen people using equations to set their spacing for holes but I can't seem to get it to work for linear pattern.
spacing = ("d1@sketch1"-(2*"edge_offset")-"component length")/(instances-1))
instances = int(("d1@sketch1"-(2*"edge_offset")-"component length")/72))
what am I doing wrong?
Figured it out.
"tot_length" = 292
"Hinge-max" = 72
"Hinge-offset" = 6
"Hinge-length" = "RD1@Annotations"
"Hinge-instance" = Int(("tot_length"-(2*"Hinge-offset")-"Hinge-length")/"Hinge-max")+2
"Hinge-space" = "tot_length"-(2*"Hinge-offset")-"Hinge-length")/("Hinge-instance"-1)
