Revision table macro
Question asked by Michael Raikh on Jul 6, 2015
Latest reply on Jul 20, 2015 by Bruce Perry
i've been trying to run a macro i've built, it fills in the revision table.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
'Edit the Revision Table
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("DetailItem504@Sheet1", "REVISIONTABLE", 0.2653942284632, 0.2752584044808, 0, False, 0, Nothing, 0)
Dim currentSheet As Object
Dim myRevisionTable As Object
Set currentSheet = Part.GetCurrentSheet()
Set myRevisionTable = currentSheet.RevisionTable
longstatus = myRevisionTable.AddRevision("")
boolstatus = Part.Extension.SelectByID2("DetailItem504@Sheet1", "REVISIONTABLE", 0.2498048865494, 0.2679361378244, 0, False, 0, Nothing, 0)
'Part.ClearSelection2 True
Dim myTable As Object
Set myTable = Part.SelectionManager.GetSelectedObject5(1)
myTable.Text(2, 0) = "#"
boolstatus = Part.Extension.SelectByID2("DetailItem504@Sheet1", "REVISIONTABLE", 0.2656304306134, 0.2676999356742, 0, False, 0, Nothing, 0)
myTable.Text(2, 1) = "-"
boolstatus = Part.Extension.SelectByID2("DetailItem504@Sheet1", "REVISIONTABLE", 0.2814559746773, 0.2658103184725, 0, False, 0, Nothing, 0)
myTable.Text(2, 2) = "0"
boolstatus = Part.Extension.SelectByID2("DetailItem504@Sheet1", "REVISIONTABLE", 0.3147604778567, 0.2676999356742, 0, False, 0, Nothing, 0)
myTable.Text(2, 3) = "New Part"
boolstatus = Part.Extension.SelectByID2("DetailItem504@Sheet1", "REVISIONTABLE", 0.3964864218288, 0.2676999356742, 0, False, 0, Nothing, 0)
myTable.Text(2, 5) = "Yossi B.-ZAE"
'Delete the Path line at the bottom of the SHEET
boolstatus = Part.Extension.SelectByID2("Sheet1", "SHEET", 0.2299456113629, 0.09981751925915, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
boolstatus = Part.Extension.SelectByID2("DetailItem503@Sheet Format1", "NOTE", 0.2930098110623, 0.00263396438633, 0, False, 0, Nothing, 0)
Part.EditDelete
Part.EditSheet
Part.EditSketch
it runs into an Run-time error '91'.
it does work some times, some times not.
what could be the solution?
I'm running SW2010
