I WANNA CREATE A RENDER LIKE THIS WITH THIS ASSEMBLY
PLEASE I NEED A GOOD EXPLAIN , IT WILL BE MY FIRST JOB ABOUT THAT.
THANK YOU.
THANK YOU.
Add a cut extrude in the assembly which create a 1/4 cut or cuts off one quarter. Then render it
While making the cut, you can select which components you want to cut.
Ed, I'm not expert with PhotoView so would not be able to help much.
But I would recommend you go to visit SOLIDWORKS World :: SOLIDWORKS World Presentations and download presentations related to rendering (PhotoView). And if you want to go in more depth, get your hands on this book Photorealististic Rendering Using SolidWorks and Photoview 360 (this seems out of stock at the moment at Amazon, so check with your VAR or SOLIDWORKS store)
