Hi
I am Trying to mirror a selected component in my Assembly, using as reference the Top Plane.
To get a better idea of the code/structure I should use, I tested the SW example "Mirror Components Example (VBA)"
found here: 2015 SOLIDWORKS API Help - Mirror Components Example (VBA)
But I get the following error:
"User-Defined Type Not Defined"
I assume its a library im missing (That I have not previously selected), can you, please, tell me which one?
Or if it is something else.
I used the macro as it is and it worked fine with no errors.
Did you changed anything in the macro? If yes what lines you've changed or added.
