Re: Macro to SaveAs a Part Configuration
Adam Hoffman Jul 3, 2015 4:40 PM (in response to Hrituc Alexandru)Try this macro out. It will save the files by the configuration name in the same folder.
DRW AND DXF.swp.zip 20.3 KB
Hrituc Alexandru Jul 6, 2015 1:53 AM (in response to Adam Hoffman)-
Adam Hoffman Jul 7, 2015 7:41 PM (in response to Hrituc Alexandru)I was using the configuration name to save with. Did you have a custom property that contained the part number?
Hrituc Alexandru Jul 8, 2015 1:52 AM (in response to Adam Hoffman)-
Adam Hoffman Jul 8, 2015 7:09 AM (in response to Hrituc Alexandru)Try this.
DRW AND DXF.swp.zip 22.4 KB
Hrituc Alexandru Jul 8, 2015 8:31 AM (in response to Adam Hoffman)Hi Adam,
It work great but i don't understand what happens with prop... I use a template which contains a block that is related to properties... It's complicated but where i work the part of the flat-pattern it's very important and throughout time tried methods and ways to make things easier but fail... I'm just beginning..I have time!
Thank you very much for help!
By the way, you are quite advanced... I don't understand everything you did inside...
Adam Hoffman Jul 8, 2015 7:04 PM (in response to Hrituc Alexandru)Glad to help! Let me know if you need anything else. Please mark my previous post as correct if you don't need anything else done.
