In Solidworks drawing,there is an option Solidworks author,if assigned it automatically gives the name of the designer (name with i log in to my system)..Also if we open the same drawing file in some other system(log in with other name) whose system name is of others,it will change author name to that system name..How can we avoid this?I dont want the name to be changed when its opened in other system..
Lingesh
I would add a custom property called Designer Name and then in the drawing title block I would type in $PRPSHEET:"Designer Name" - then all the history stays with that part or assembly
