We want to use the library but all the parts used should be copied to the project folder without any links to the library. Is there some option to do this whicht I can't find or should we create our own macro using the API to create something like this?
Can't you simply copy from the library folder and paste into project folder? If not then what is the issue? Any specific reason you can't use directly from library?
