Hello all, does this setting improve the curve quality on your drawings and/or models? I check it when I'm working with my drawings because I though it made the curve lines a little smoother, but it might just be my imagination. Anyway, if it is supposed to do that, why does it keep getting unchecked when I reopen my files? I know it is checked when it is saved, on both the model and drawing.
Ryan
Because you need to save the setting in your drawing template file and drawing format file....
After you do that you won't need to change it again, unless you want to.
