Hello, i need some help with my model! I am new to Solidworks. I am a Maya/3D max user and find modeling in Solid works a bit confusing and complicated. I have this model (on the picture) and i want to raise those 2 points/verticies between those pyramid shapes on my model. I dont want to have that "hole" pointing intside the model between them. Instead i have marked everything on the picture below! I marked the way i want my vertex to be located with red lines. Those pyramid shapes i made by drawing 2 sketches on 2 sides of the model ,then creating planes on 3D-Sketches parallel to those sides, then creating points where i want the highest point of those pyramids to be and then chosing my 4 side sketches and those points and applying Boundary Boss/Base! But i have no idea how to raise those vertexes between those pyramids... Thanks for help guys!Thanks for help!
gm John - First thing I noticed was in your 3D sketch there is a - sign ahead of the sketch - that tells us the sketch is under defined, in other words you need to lock in all your sketches with dimensions or equal lines etc... Depending on the sketch and how it relates you may only need one dimension to raise the vertexes up like you need them to move..
Could you upload the part?
