After leaving a connector looking great with all the wiring
the right color and diameters, I return only to find it messed up
with the wrong colors and diameters. Revisiting the wire editor
shows that two wires are associated to one route. This happened all
by itself(!).
Also the minimum bend radii, wire diameters, wire colors and other values in the user defined wire library I have have to be re-input since they revert to some magical default values.
Maybe the two above are linked?
Please confirm, deny and suggest possible remedies
Best Regards,
G
I am using routing in swx 2007 sp3.1. on x32 windows xp (4GB RAM)
Best Regards,
G
Am I doing something wrong, or is this a known bug?
Mike Barber
