ATAlan Thomason30/06/2015
Hi All...
When designing crankshafts and camshafts, it is pretty common to need to rotate and translate a pattern, for instance a lobe on a camshaft. I've done this in two different ways. The first is to make a linear pattern (say sketch driven) and then rotate the elements individually. The other is to make sketches at each station and make the rotation in a sketch whose dimension is tied to a design table. My new favorite is the latter, although it takes a lot of time to set up.
Am I missing an easier method? For instance, if this table driven pattern had rotation as well as translation (although it would need a Z axis as well) I would be in good shape.
Best Regards and Thanks in Advance..
Alan
