Re: Change sheet metal feature k-factor
Arif Akbas Jun 27, 2015 11:53 AM (in response to Arif Akbas)How do I edit the code to do things in the picture
Add here whether you're a person
Thank you in advance you make friends
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
boolstatus = Part.Extension.SelectByID2("Sheet-Metal", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
Arif Akbas Jun 27, 2015 4:48 PM (in response to Arif Akbas)does not have to answer
I can not ask you do this macro
k-factor changing macro urgent need
Arif Akbas Jun 29, 2015 3:42 AM (in response to Tapani Sjoman)I do not know API
you add structure here
thanks
Tapani Sjoman Jul 1, 2015 10:28 AM (in response to Arif Akbas)I coul'd make it work .
My idea was to chande default type and value and after that traverse every sheet metal feature to use default values. Still stuck with the first step (change default values). Anybody have a code for this?
Deepak Gupta Jul 1, 2015 10:37 AM (in response to Tapani Sjoman)Tapani, it can be done but need some time.
Arif Akbas Jul 1, 2015 11:53 AM (in response to Deepak Gupta)hello
What do you do when you add the macro forum
This macro is very urgent need
thanks
Solidworks Selim Dec 18, 2015 1:17 AM (in response to Deepak Gupta)Tapani, it can be done but need some time.
did you do it ? gupta
Deepak Gupta Dec 22, 2015 7:36 AM (in response to Solidworks Selim)Sorry, never got the time to do that.
Arif Akbas Jul 4, 2015 5:51 PM (in response to Arif Akbas)hello gupta this macro could it make you make it very easy for your very need of all sheet metal parts in the assembly kfactor You have to change the value of the macro
Arif Akbas Jul 6, 2015 6:32 AM (in response to Arif Akbas)Does anyone have information?
Do not have to write the answer?
Arif Akbas Jan 4, 2016 8:18 AM (in response to Arif Akbas)Hello gupta
Have you done the macro ?
needed immediately
Deepak Gupta Jan 4, 2016 8:23 AM (in response to Arif Akbas)Check and modify this program as required: Change all sheet metal features radius add-in [FREE]
Viktor Bovzdarenko Jan 17, 2016 11:14 PM (in response to Arif Akbas)Hi Arif,
Try to use a free BETA version of batch tool "#TASK". It has a library where macro for modifying K-factor can be found.
Just drag the folder with all your parts, specify new K-factor and it will be changed.
Please note that K-factor is changed on top level. If individual bend has a different (overriden) K-factor then it will not be changed but you will be warned
If you have a lot of files and SolidWorks hangs somewhere in the process then tool will reload SolidWorks and continue creating drawings
Please follow the link to download this batch tool: https://cloud.centralinnovation.com.au/WebSharpSwTask/Home/Index?lang=en
Please let me know if you want to have a bit different behavior of the macro so that I can modify it for you
It is a Beta version of the application. Central Innovation takes no responsibility of any loss or damage incurred through the use of #TASK. So please, back up your data if you haven’t done so already before running #TASK.
instructions.en.pdf 320.5 KB
Arif Akbas Jan 13, 2016 1:57 AM (in response to Arif Akbas)thanks
Is not this free ?
Arif Akbas Jan 13, 2016 2:11 AM (in response to Arif Akbas)Can not find #TASK None
Is there a way
How does it work
Arif Akbas Jan 13, 2016 2:20 AM (in response to Arif Akbas)Add macro within the program
How does it work. Add video
Web library task appears blank
add macro
Deepak Gupta Jan 13, 2016 2:32 AM (in response to Arif Akbas)Did you checked the instruction in this post: Re: Change sheet metal feature k-factor
Arif Akbas Jan 13, 2016 2:47 AM (in response to Deepak Gupta)yes
I checked
#TASK web library
How to create
Viktor Bovzdarenko Jan 13, 2016 4:09 AM (in response to Arif Akbas)If you installed the application - link: #TASK ,then simply press the "Globe" button to rich the library
I will attach video tutorial tomorrow
Let me know if you have any questions
Arif Akbas Jan 13, 2016 4:30 AM (in response to Viktor Bovzdarenko)-
Deepak Gupta Jan 13, 2016 4:34 AM (in response to Arif Akbas)Make sure SOLIDWORKS is running before you open #TASK
Arif Akbas Jan 13, 2016 5:18 AM (in response to Deepak Gupta)yes
software installed
SolidWorks closed trial did not
SolidWorks open trial did not
add video
Deepak Gupta Jan 13, 2016 5:57 AM (in response to Arif Akbas)Here is a working video. Make sure no proxy or firewall is blocking the application to access the online directory.
#TASK Working.zip 930.8 KB
Arif Akbas Jan 13, 2016 6:22 AM (in response to Deepak Gupta)-
Viktor Bovzdarenko Jan 13, 2016 6:27 PM (in response to Arif Akbas)Could you please restart #TASK after installation (you will be able to see all library )
Try to launch solidworks manually before launching #Task; please check if you have administrative permissions on your PC and internet connection. Also check if the application is not blocked by firewall as Deepak Gupta suggested.
Could you please also specify which version of SolidWorks is installed on your PC?
Deepak Gupta Jan 13, 2016 7:12 AM (in response to Arif Akbas)Have you restarted your system after installation OR close #TASK and restart it to make sure it connects properly with the library.
Viktor Bovzdarenko Jan 14, 2016 12:45 AM (in response to Arif Akbas)Hi Arif
I sent you a private message with installation help for #task
Please also watch a small introductory video: #TASK - your very own SolidWorks assistant - YouTube
Regards
Arif Akbas Jan 14, 2016 1:08 AM (in response to Viktor Bovzdarenko)It did not work
file attachment,
CI.SharpSwTask.rar 1.3 KB
Deepak Gupta Jan 15, 2016 7:03 AM (in response to Arif Akbas)Are you using a legitimate version of SOLIDWORKS?
Arif Akbas Jan 15, 2016 7:56 AM (in response to Deepak Gupta)yes original
licensed version
Deepak Gupta Jan 15, 2016 8:41 AM (in response to Arif Akbas)What is your version as I don't see the SW version in the TASK window drop down.
Arif Akbas Jan 15, 2016 8:43 AM (in response to Arif Akbas)I chose the desktop shortcut
It does not appear in the program
Arif Akbas Jan 16, 2016 6:40 AM (in response to Arif Akbas)Can we add the macro to the program
Trying program online
Add the original program here
Artem Taturevych Jan 17, 2016 6:11 AM (in response to Arif Akbas)Hi Arif,
I'm sorry for the issues you have with the #TASK. The fact that you had to select the path to SolidWorks manually means that you might not have a proper permissions to read some registry keys or you are using x32 bit version of SolidWorks in x64 environment, can this be the case? When #TASK cannot access the registry to find the installed versions of SolidWorks it is asking to select the full path to SolidWorks, not a shortcut. So something like C:\Program Files\SolidWorks 2015\SLDWORKS.exe (please read this document for some more information: http://cloud.ic3d.com.au/sharp_task/docs/Troubleshooting.en.pdf).
Artem
