before render
________________________
After Render
This isn't an expected rendered image.
Thanks in advance
before render
After Render
Thanks in advance
Dear Deepak,
Thanks for reply. As we make transparent those components(which I intend to make hidden line removed) it will look as wire-frame mode not hidden line removed.
e.g. please see below image
This is simple model so looks ok, but in case the components are high in numbers and or holds much complexity then it will give really bad appearance in render.
Use Contour rendering with suggestions by Marlon Banta here: Re: Rendering wire frame
Here is quick render result.
