when i opened this subassly it says couldnt find the file and give 3 options ---to fbrowse the file,or suppress the component and suppress all the component..
actually all the files are placed in the same folder and location..whats wrong with the assly?
Is there any option to give location of all those missing files in one step?am now browsing all files and it takes lot of time..
Thanks...
ON the file open window, select the assembly and click on references (don't open assembly). In the pop up window, check the reference path and make sure those are correct else you can double click on the paths and correct them. You can do this only one path at a time.
OR open all the files and then open assembly and this should work too. And once assembly is fully opened, save it.
